Single annulus concentric cylinder
Old   February 3, 2011, 00:40
Default Single annulus concentric cylinder
Satya prakash shukla
Satya prakash is on a distinguished road
I am working on fluent towards a single annulus concentric cyinder where i am facing a problem in convergence critieria in continuity. My analysis involves a single annulus geometry vertical cylinder with both end closed and iam using velocity inlet and pressure outlet as inlet and outlet condition also a constant heat flux is supplied at the inner cylinder with constant surface temperature for outer cylinder. Can anyone please help me towards these
Satya prakash is offline   Reply With Quote
single annulus
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
LES concentric annulus Alex FLUENT 0 June 14, 2005 14:48
Turbulent concentric annulus JonS Main CFD Forum 3 August 10, 2004 07:02
drag coeffecient of a single cylinder Allan FLUENT 4 February 3, 2004 10:46
