Backward Facing Step
Old   May 30, 2012, 09:40
Default Backward Facing Step
L.M. Yang
LBMer_Young is on a distinguished road
Hi, guys
I am simulating the laminar backward facing step with a 2D incompressible CFD code. Could any of you direct me how to set the inlet and outlet boundary conditions? The velocity profile of inlet boundary have been obtained. However, how do I set the pressure of inlet boundary and pressure and velocity of outlet boundary?
With kind regards,
Laman Yang
LBMer_Young is offline   Reply With Quote
Old   May 30, 2012, 14:39
Peter Galimutti
p.galimutti is on a distinguished road
Since you already have a velocity profile, you do not need to set any inlet pressure. Pressure is implicit calculation based on velocity.
At the outlet 1 atm pressure can be given!
BTW, you said you are using code, so giving boundary conditions is specific to that code and check the manual on how to define b.cs
p.galimutti is offline   Reply With Quote
Old   May 30, 2012, 21:03
L.M. Yang
Hi, Peter
Thanks for you comments. Actually, the code is developed by myself. In this code, the conventional Navier-Stokes equation is solved rather than its incompressible forms (e.g. governing equation for artificial compressibility method and pre-conditioning method). So, in the inlet boundary there are three characteristics enter and one leaves the physical domain, i.e., the pressure in b.c need to extrapolate from the interior of the physical domain. My confusion is how to calculate the pressure. Similarly, the velocities in outlet b.c need to extrapolate from the interior of the physical domain. How could I evaluate the velocities in outlet b.c.
regards
Old   May 31, 2012, 08:35
Andrew
mettler is on a distinguished road
have you thought about transforming your equations to the streamline-vorticity equations? that way your pressure term drops out, and the bc's are pretty straight forward.
mettler is offline   Reply With Quote
Old   May 31, 2012, 10:29
L.M. Yang
Thanks for your advice. However, the flux solver in my code is developed by lattice Boltzmann method and the governing equation is the conventional Navier-Stokes equation. It is harder to transform the governing equation.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Backward facing step. Fluids Main CFD Forum 7 December 4, 2012 11:28
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
