-   Main CFD Forum (https://www.cfd-online.com/Forums/main/)
-   -   Convergence problems (https://www.cfd-online.com/Forums/main/102753-convergence-problems.html)
saisanthoshm88 June 1, 2012 06:42
Could some one please explain if the lack of prisms and the use of a pure tet mesh can be a reason for convergence problems in CFD
Far June 1, 2012 09:42
No. May be accuracy is lost, but shouldn't affect the convergence.
cdegroot June 1, 2012 15:48
I respectfully disagree. A poor quality mesh can hurt convergence in several ways. Assuming a FV discretization, integration points will be further from the vector connecting neighboring cells, meaning the method becomes more "explicit" and will take more coefficient iterations to converge. Also limiters can be more active, which hurts convergence.
Now I am not saying this in general for tets. It is more mesh quality that can be a problem.
Far June 2, 2012 02:39
I agree ;)
Far June 2, 2012 11:46
some updates from CFX forum
Here is update from CFX forum
Originally Posted by ghorrocks (Post 364406)
If you are saying you have a turbulent simulation and are simply using a tet mesh with no inflation layer and it is not converging - then no, inflation usually makes convergence harder, not easier. It is unlikely the lack of inflation layers is causing the problem. Something else is causing your convergence issue.
cdegroot June 2, 2012 12:51
Another good point. Tets are certainly less accurate in boundary layers in part because of greater false diffusion and as we know a more diffusive scheme is easier to converge. Like I said before if the mesh has very bad quality that could cause convergence issues, but most likely it is something else. You should absolutely be able to get convergence without prisms.
