flow past a step ?
Old   July 17, 1999, 04:24
Default flow past a step ?
thampy
hi,
I'm trying to solve the 2D NS equations over a step as a part of my undergrad project.Could someone tell me if there is any problems as such in solving the problem numerically ? if yes how do I circumvent it ?
Thanking you Thampy
Old   July 17, 1999, 15:54
Default Re: flow past a step ?
John C. Chien
(1). Flow over a step ( normally a backward facing step ) is a standard test case for Navier-Stokes code. (2). If you perform the necessary journal search first, you should be able to find tons of information.
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Flow past orifice aurel Main CFD Forum 0 January 27, 2009 06:46
Rearward Step (Base Flow) cfdxue Main CFD Forum 0 October 12, 2008 01:31
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
