July 3, 2012, 02:08 |
micro scale calculation problem
Dear all,
Now my simulation model is that 10mm cyclinder with 20µm little radial clearance. I want to calculate the fluid is through the clearance condition. -which turbulent model and wall function is suitable to use? - how can i check mesh size in layer position with y plus in a reasonable range? hope someone can help me. thank you in advance |
July 3, 2012, 05:56 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
July 3, 2012, 22:56 |
#3 | |
In the radial clearance, the velocity is 30m/s, which is turbulent structure. now my main issue is how to adapt the mesh size in reasonable range to assure the calculation accurate. have a nice day guava |
July 4, 2012, 03:44 |
#4 | |
Rep Power: 71 |
Hi, I am not an expert about microfluidic, I just see from some estimation, velocity and lenght of 20µm turn out to produce a small Re number. What about the axial velocity? I doubt that the energy production can balance the energy dissipation to substain turbulent structures and produce inertial range in the energy spectra... but I could be in error |
July 4, 2012, 04:32 |
Alex
Rep Power: 46 |
What kind of fluid are you simulating? How high is the viscosity?
Estimating Re with an approximate value of air (1.5 e-5 m^2 s^-1) yields Re=40. So your flow is definitely laminar (assuming the fluid you use doesn't have a lower viscosity than air) since the critical Re is in the range of 2300 for a circular pipe. |
July 4, 2012, 21:02 |
#6 | |
viscosity is 2.24e-07 m^2 s^-1, and i have check the Re number, which is larger than 2300 in the clearance. I can't upload the model as a picture, maybe the problem didn't give a clear description. my proposal for this case is to know the leakage with piston through the clearance 20 µm. have a nice day guava |
July 5, 2012, 01:26 |
Alex
Rep Power: 46 |
Ok sorry for the detour, now lets get back to your initial question.
Since Re is still pretty low, the computational cost of fully resolving the boundary layer without a wall-function should not be too high. Try to get the Y+ values below 1 to achieve this with a small growth factor (1.05-1.1) in wall-normal direction. Thanks to the low Re again, the choice of the turbulence model will not be too important in this simulation. Any of the basic k-epsilon formulations should yield reasonable results. |
July 5, 2012, 02:27 |
#8 | |
Rep Power: 71 |
I agree...what's more, your Re_tau is quite low such as a DNS is realizable |
Attempt to run rhoPisoTwinParcelFoam on micro scale | jabecker | OpenFOAM Running, Solving & CFD | 3 | April 13, 2021 08:52 |
How to find a good time scale strategy? | StefanG | CFX | 19 | June 8, 2012 08:41 |
[OpenFOAM] Paraview color scale problem | Jdog | ParaView | 1 | November 19, 2011 06:49 |
scale problem | hughyang | FLUENT | 0 | January 26, 2004 14:52 |
how to solve this problem in CFX5 calculation? | cfxbeginer | CFX | 2 | May 1, 2003 08:55 |
