LBM lift and drag
Old   July 17, 2012, 06:56
Default LBM lift and drag
Albert Puig
Puigar is on a distinguished road
Dear community,
I am a newbie of this forum.
I am working on a 2D developed laminar flow (Re 100) in a channel and a square cylinder as an obstacle. Simple stuff
I want to calculate de drag coefficient and the peak-to-peak lift coefficient, so which is the best strategy to calculate it?
I am actually doing it with immersed surface method, but the results I have are twice the bibliography.
I use as planform area the height of the square which is facing the flow. dynamic pressure also is easy to get.
but I have doubts of how I can obtain the lift and drag FORCES in terms of symmetry, consideration of pressure and viscosity and also domain determination for the calculation zone.
Can someone explain how to calculate the lift and drag forces in a simple way for these conditions??
Thank you in advance
Puigar is offline   Reply With Quote
calculations, coefficient drag, drag, lbm, lift
Lift and Drag ??? Yogibear STAR-CCM+ 5 November 2, 2023 17:14
Drag and Lift coefficient for diffusor rego STAR-CCM+ 3 May 7, 2012 18:05
[ANSYS Meshing] Lift & Drag Meshing Techniques tylerplowright ANSYS Meshing & Geometry 6 May 2, 2012 23:53
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
