Help! How to hold turbulence in a 2d channel flow RANS simulation
Newbie here.
I am doing a 2D rans simulation to investigate some turbulence models. I am wondering how to make the flow turbulent? For example in a simple Re_tau=180 channel flow, or a little bit more than that. Pressure gradient driven, using some low Re turbulence model, and keep the mesh having y+<1. Then I set the initial nut=100*nu, k/e>100*delta_t, mass is kept constant on the solver's side (I am using an unsteady solver (URANS)). But I found the flow is always laminar or laminarized. This is very annoying. But I read so many papers, they all have a perfect velocity profile, How did they do that? Any secrets? Or what did I do wrong? Any ideas? -------- 1/153 |
<deleted><deleted><deleted><deleted>
Thanks for helping. Yes the velocity profile is here: [shared just for 24 hours]
http://f.imgtmp.com/Dcdfq.jpg |
Is that because 2D cant sustain the turbulence structures, so to damp out all the turbulence? Or is that I should use RANS not URANS?
No ... you are solving a 2D statistically steady solution, you never see in RANS any other variable that zero-order statistics.... But your problem is that you are solving a smaller Re number, your profile arrives at y+ about 10 at the half-heigh! |
I will test with other LRN models to see if my new implemented model is wrong somewhere. But have you ever use steady RANS to get a correct profile before? Which turb model did you use? Thanks
RANS is perfect in turbulent channel flow, you have some wrong in your setting/input
