Runge Kutta vs adams bashforth time marching
Old   December 23, 2005, 14:26
Default Runge Kutta vs adams bashforth time marching
vasanth
Hello friends,
I changed the time marching scheme from runge kutta to adams bashforth and the code blows up (it is not the time step problem).I am running a case of flow over airfoil .The point where the code starts to get unstable is the front side wall boundary of the airfoil.
Can anybody guess what the problem could be.
Thanks in advance vasanth
Old   December 23, 2005, 17:00
Default Re: Runge Kutta vs adams bashforth time marching
Srinath
Adam BAshforth, contrary to popular belief leads to spurious solutions... Check the following paper... PLZ remember Runga-Kutta is always better for time stepping
A comparative study of time advancement methods for solving Navier-Stokes equations -Journal of Scientific Computing Vol-21(2), pp 225-250. Oct. 2004
Old   December 24, 2005, 16:17
vasanth
Thank you srinath , I undestand that. It might give wrong results but it should not blow up after a few steps. I looked at the solution and saw that the code blows up at the wall. I dont know why this is happenening. It is because of the beta values.
Thanks in advance
Old   December 25, 2005, 09:49
Srinath
Are you sure your problem is because of the time marching scheme? If the solution blows up at the wall, then you should probably take a closer look at the boundary conditions and their implementations. I suggest that you run your problem for the steady state case and if the solution still blows up then it has nothing to do with the time stepping algorithm. Good luck
Old   December 26, 2005, 02:14
vasanth
Thank you Srinath. The problem at the wall was fixed.The code is actually blowing up at the trailing edge of the airfoil.I have to investigate why ths was not happening for runge kutta time marching and why is it happeing for adams bashforth time marching.
any suggestions friends ?
Old   January 1, 2006, 01:17
versi
The numerical stability depends on CFL. Different kinds of Runge-Kutta, and Bashforth have different bounds of CFL. The specific marching scheme determines its upper bound of CFL.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
what is time marching problem and method F. Zhen Main CFD Forum 0 May 9, 2003 15:51
Diagonally Dominate Runge Kutta Method Anthony Iannetti Main CFD Forum 0 January 23, 2001 22:27
