July 12, 2004, 15:56 |
Peric Code Output
Hello All,
I tried using Peric code and did not know what was the format of the output files ? The program compiled and run asks for output files...what is the extension of those files ? Thanks CFDtoy |
July 12, 2004, 19:20 |
How to Use Peric's CFD Code
I think Peric Code doesnt sound right as such. I downloaded Milovan Peric's CFD Code and ran it for a 2D Lid Driven Cavity problem. I wasnt sure how to address the results. The problem was in giving the name of the output file since I did not know the kinda output the progrm used to visualize the data.
CFDtoy |
July 13, 2004, 00:35 |
Re: How to Use Peric's CFD Code
You should find the code plot.f in peric's website. This takes as input the data which is output from the solvers written by peric (for example your 2d lid problem). Plot.f will read the output file and generate vector and contour plots (I believe only postscript format).
Otherwise you can easily modify the solver output format (if you know f77) to generate output suitable for say tecplot, etc. |
July 13, 2004, 11:38 |
Hi Anindya
Thanks for the reply. If you have used the Peric's Code, What is the name of the output file that you enter while running the code? That would clear my doubts. Thanks for your help and time CFDtoy |
July 15, 2004, 08:33 |
Please read the readme file. I believe it explains clearly what the output files will be. There are different output files, ex name.out (residuals, etc, monitored value), name.x (postprocessing) etc, where name is the name of the files you prepared as input (name.gin, name.cin, name.pin)
August 5, 2004, 15:20 |
I am trying to run Prof. Peric's code. But do not know how to include the *.inp files along with the *.f files.I am using a g77 compiler. A quick reply would be well appreciated.
August 5, 2004, 16:38 |
How to Visualise the results from Perics Code
How do I visualise the results obtained from the simulation of Peric's code. I have obtained the data file, but I cannot understand about NGRID. Any help is well appreciated
September 14, 2012, 14:11 |
How to run the peric's code
Rep Power: 14 |
Hello everyone
I have some challenge in using the peric code For example consider 2DGL, when I generate the gird for the geometry, what's the next step??? Should I use the Caffa.f or user.f ???? I read the read me file, but I don't understand. Thanks for your help. |
Debugging Unsteady 2-D Panel Method Code: Wake Modeling | RajeshAero | Main CFD Forum | 5 | November 10, 2011 05:48 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
[Other] Output Format of MetaMesh | t42 | OpenFOAM Meshing & Mesh Conversion | 0 | August 3, 2007 04:28 |
File Output Code | cbadke | OpenFOAM | 1 | March 18, 2005 13:25 |
Help with DPM UDF for OUTPUT needed | Zhengcai Ye | FLUENT | 0 | January 5, 2004 16:58 |
