May 22, 2019, 13:11 |
Standard State enthalpy
Rep Power: 7 |
I am modeling water and air evaporation. I read that I can use standard state enthalpy to model latent heat. Water vapor and water SSE should be defined somehow the difference between them become latent heat. So, if we consider that the SSE is 43999434 J/Kmol, how should I define this for both of them? and what is the sign of them (negative, positive)? Thanks, Amin |
May 29, 2019, 16:34 |
vivek
Rep Power: 7 |
set the standard stater enthalpy for water to zero and put all latent heat on the vapor side
standard state enthalpy |
Standard state Enthalpy difference of same material | shinesli | FLUENT | 2 | April 30, 2016 17:59 |
Problems about the standard state enthalpy | DDDDKKKK | FLUENT | 0 | April 8, 2016 22:37 |
Solver for transonic flow? | Martin Hegedus | OpenFOAM Running, Solving & CFD | 22 | December 16, 2015 04:59 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Defining Inlet Mixture Enthalpy | Munggang | FLUENT | 0 | March 2, 2012 16:50 |
