January 26, 2006, 00:46 |
mesh generation
whenever we mesh a model, what is the procedure to take the mesh size. how can we say that the mesh that we generate is correct. do we need to follow any principle that must be satisfied.
thanks and waiting for ur reply. srikanth |
January 26, 2006, 05:02 |
Re: mesh generation
Meshing a model can be considered a kind of art of sculpture and depends of your experience besides the physics you'd like to solve with this model.
Most of the times your mesher (a good mesher) will produce "correct" meshes or an error (or warning) if it isn't possible to generate one. I guess your question is related to the quality of the mesh. Regarding mesh quality, your mesher (again) should be able to provide informations about some kind of mesh quality metrics (aspect ratio, edge ratio, minimal angle, Jacobian, etc...). Cheers Renato. |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
mesh generation for in-cylinder fluent simulation | hennas | ANSYS Meshing & Geometry | 2 | May 31, 2011 15:08 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
