July 21, 1999, 07:08 |
Shallow Watter Equation
I am looking for a site where i can find how to establish Shallow Watter Equations system and its resolution with finite element method
July 21, 1999, 10:11 |
Re: Shallow Watter Equation
Hi there,
For the Shallow Water Equations you can look for example at the book of Pedlosky: Pedlosky, 1987, Geophysical Fluid Dynamics, Springer Verlag, Berlin. And for the Finite Element Method you can look at the book of Hughes: Hugues, 1987, The Finite Element Methods (Prentice-Hall, New Jersey). I am not really aware of any work solving the Shallow Water Equations with the Finite Element method, so I cannot give direct references on that. There is a tremendous amount of work done solving the time dependent 2D Shallow Water Equations using finite difference and especially using the spectral methods (for modeling planetary atmospheres, or for the weather prediction even; see e.g. Cho and Polvani, 1996, Physics of Fluids, vol.8, page 1531.) I hope this helps, PG. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Problem in implementation of Shallow water equation | DeliriousPsycho | Main CFD Forum | 1 | December 23, 2011 07:01 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
BCs of hyperbolic Shallow Water Equation | Kang, S. K. | Main CFD Forum | 4 | November 21, 2000 21:20 |
