Minimum number of cells for aircrat cfd analysis
Old   August 18, 2012, 23:13
Default Minimum number of cells for aircrat cfd analysis
nauman hashmi
nauman55 is on a distinguished road
hi i want to know that what should be the minimum number of cells or element are required for cfd analysis of aircraft cfd. request quote any international standard.
regards
nauman55 is offline   Reply With Quote
Old   August 19, 2012, 04:53
cfdnewbie
cfdnewbie is on a distinguished road
that depends on so many boundary conditions and parameters that it is impossible to answer! you should provide more details on what you are interested in...
cfdnewbie is offline   Reply With Quote
Old   August 19, 2012, 05:45
Default RE
nauman hashmi
i want to conduct cfd analysis in straight and level at one speed and one altitude. later on i have to conduct FSI. for accurate results what should be number of cells for this?
Old   August 19, 2012, 06:02
cfdnewbie
what Reynolds number? what mach number? turbulent? laminar? What effects are you interested in? is there separation? What scheme are you using? What grid?
Old   August 19, 2012, 06:04
Default RE
nauman hashmi
0.8 mach number, turbulent flow at 30000 feet. interested in aerodynamic loads on surface. not flow analysis.
Old   August 19, 2012, 06:09
cfdnewbie
so what scheme will you use? what order of spatial approximation? Is shock capturing available? What type of grid? can you adapt the grid during the computation? What is your Reynolds number (approx. ) ?
The question you are posing here is very general, it is like "how much do I need to spend for a car?"....
Old   August 19, 2012, 07:41
leflix is on a distinguished road
His mach number is 0.8 so no problem with shock.
leflix is offline   Reply With Quote
Old   August 19, 2012, 07:59
cfdnewbie
if he does an airfoil calculation, 0.8 might be sufficiently high to produce shocks on the expansion side!
Old   August 19, 2012, 10:01
Default bit more detail
nauman hashmi
sir i would be using SA model. my grid is tetra-hdyron with prismatic boundary layer. i can use grid adaptation, i am using fluent and ansys for cfd and meshing respectively. my main aim is calculate the aerodynamic loads on the lifting body by using Fluid structure interaction.
regards
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 04:15
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
