Far Field flow Prediction
Old   August 20, 2012, 21:02
Default Far Field flow Prediction
NGH
NGH
NGH is on a distinguished road
Hi
I would like to know the flow field prediction on the water surface. The case is modelling the flow field around an underwater explosion and how the pressure and velocity propagate up to the water surface. As the water depth is around 20 to 30 m, thus I would like to split up the computational domain if possible. If there a method to model the flow field from let say 30 m to 20m, then 20m to the water surface? Or is there any empircal correlation to extraploate the flow field from 30m depth to water surface? Thanks
NGH is offline   Reply With Quote
Old   August 21, 2012, 05:00
Rami Ben-Zvi
Rami is on a distinguished road
This is an active research field, usually termed non-reflecting BC, absorbing BC, radiation BC, perfectly matched layer and other names. Google for Dan Givoli et al papers in the last 2-3 years and follow their references.
Rami is offline   Reply With Quote
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 18, 2009 23:24
Porous domain in a flow field rikio CFX 7 August 25, 2009 22:39
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
