KIVA - tinvrt overflow
Old   January 17, 2006, 09:53
Default KIVA - tinvrt overflow
Tomislav
I am trying to simulate the scavenging of a 2stroke diesel engine. However, my simulation runs for only few ca degrees and I obtain the error message: tinvrt overflow... or temperature overflow... or 50 temperature iterations..
The program cuts down the timestep several times, but it doesn't help. It stops.
When I try to follow the reason I notice that the sie (specific internal energy) becomes negative. Is this a normal behaviour? How could I cure it? Should I look for the reason in the bad mesh quality?
Old   January 18, 2006, 01:19
Default Re: KIVA - tinvrt overflow
Felix
I frequently get into that problem either (I am simulating ad HSDI engine with HCCI operation). The output file always suggested cutting dti but seems not working for me either. While I am not sure if this is okay, I frequently run the simulation with increased tcut and tcute for several crank angles and then reverting them back to bypass the crashing point. This seems always working for me.
Solution variables goes outside upper limit -how to localize fatal overflow occurance Dimone CFX 2 January 21, 2011 06:35
mesh converter in KIVA 4 DaIN Main CFD Forum 0 June 7, 2010 12:54
kiva 4 installation fahdme OpenFOAM Installation 3 May 25, 2010 17:54
Tinvrt Overflow in KIVA Felix Main CFD Forum 0 November 27, 2006 01:02
PDF - conserved scalar approach in KIVA vega Main CFD Forum 0 July 5, 2005 02:49
