Formula for 2nd order upwind scheme for non-uniform grids? |
August 30, 2012, 03:57 |
TWB
Rep Power: 19 |
I've seen the formula for 2nd order upwind scheme for uniform grids as: phi_e = 1.5*phi_P - 0.5*phi_W for u_e > 0 phi_e = 1.5*phi_E - 0.5*phi_EE for u_e < 0 Is there a formula meant for non-uniform grids as well? Thanks |
August 30, 2012, 04:57 |
Rep Power: 15 |
Hi, you can try to derive it. Just take the Taylor expansions around the nodes E and EE, taking into account the different grid spacing for node i.
The formulas you showed is a particular case where the grid spacing is constant. Under this assumption, the grid spacings appearing in numerator and denominator of your expressions when you solve for phi_e cancel out and disappears from the equation. However, the different will appear in the expression of phi_e if you consider grid non-uniformity. I hope it helps. Cheers, Michujo. |
August 30, 2012, 17:25 |
#3 | |
Filippo Maria Denaro
Rep Power: 71 |
I suggest to construct a second degree polynomial on non-uniform stencil in such a way that if u_e>0 then Phi_W,Phi_P, Phi_E are involved (the counterpart for u_e<0 involves Phi_P,Phi_E, Phi_EE). This way the use of Phi_P ensures better stability properties |
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 18:19 |
Free jet simulation | msarkar | OpenFOAM Running, Solving & CFD | 39 | May 11, 2021 13:21 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
singularity? | mihaipruna | OpenFOAM Running, Solving & CFD | 5 | April 24, 2012 17:18 |
second order FD upwind scheme | Heinz Wilkening | Main CFD Forum | 2 | November 3, 1998 14:33 |
