MAC method solve for pressure at boundry
Old   January 11, 2006, 13:49
Default MAC method solve for pressure at boundry
Ron
Hi I am a CFD newbie. Just learn MAC method from a CFD text. I trying to solve for the velocity profile in a rigid hollow pipe.
How do you solve for pressure with G-S method on the boundry if it is require the pressure points outside of the domain is required?
Would you make different assumption to solve the pressure at the inlet boundry form the boundry at the wall of the pipe?
Any help is appreciated.
Old   January 12, 2006, 09:28
Default Re: MAC method solve for pressure at boundry
versi
Assume P(0,j) is near to P(1,j), with the former being ghost point pressure, and P(1,j) is the one at the first inner mesh center. There must be some relations regarding P(0,j)and P(1,j),and possibly, P(2,j), from boundary condition of P, or by applying corresponding momentum equation at the BC middle way between p(0,j) and p(1,j). These relations can be incorprated in G-S method for pressure.
Old   January 28, 2006, 02:14
Default Re: MAC method solve for pressure at boundry *NM*
mahmoud
How to solve equations from Penalty FEM in Fluids? Yiling Main CFD Forum 4 March 25, 2003 16:43
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 02:34
CFD method for High Re flow Toshiyuki Arima Main CFD Forum 3 May 29, 2001 11:18
use of MAC method to solve sloshing problem. S.R.SAHI Main CFD Forum 1 April 15, 1999 22:28
Marker And Cell method (MAC) Albert Badal Main CFD Forum 0 February 27, 1999 19:53
