January 16, 2006, 04:09 |
airfoil grid generation
Please I'm using structured C-grid generation to simulate numerically flow about NACA airfoil. My code program diverge after it reachs 10**(-4) between two concequative velocity values.
That's some details of my code program: 2D, incomressible, laminar, viscous flow grid dimension:191x145 streching coeffecients: 0.12, 0.12 Re number: 2x10**3 relaxation parameters for all variables: 0.05 finite volumes method with upwind second order scheem SIMPLER Algorithm Please i'm ready for more details if you would like help me to run my code. |
January 16, 2006, 05:15 |
Re: airfoil grid generation
Just try running ur code without the airfoil...just a plane flow..theoretically the solution should not change with time. If u still get an error, i think the probability of finding an error due to the grid (like calculation of angles etc) is more. The other thing i suggest is try a simple test case--a flat plate or flow between parallel plates and see wat happens. regards, B787 |
January 16, 2006, 06:46 |
Thanks verry much for y're interest, I'm runing the code for permanent case and zero angle of attack. But i have a difficulties in imposing boundary conditions in numerical domain
February 6, 2006, 23:09 |
I need only a grid generation soft (free) for simulate a C or O grid about a 2D profile (orthogonal mesh in a computational plane), please if you know some one link send me it.
Thanks Santiago Argentina |
February 6, 2006, 23:42 |
studentfluent.com, click on mesh lib and download all the mesh files you wish for free
February 7, 2006, 10:27 |
u can try ugrid or shore-cfd. one is o-grid, another is c-grid. google them...
February 10, 2006, 21:04 |
thanks Ahmed, IŽll try. Later I`ll talk about.
Bye |
February 10, 2006, 21:05 |
thanks zonexo, IŽll try. Later I`ll talk about.
Bye |
Help! Validity of unstructured grid on S809 airfoil | didiean | FLUENT | 11 | April 3, 2011 02:10 |
2D airfoil simulation, turbulence, boundary layer, unstructured grid | louis.langouche@gmail.com | FLUENT | 0 | March 3, 2010 08:19 |
cartesian grid generation method | Abu Taleb | Main CFD Forum | 7 | April 14, 2001 09:49 |
Cartesian grid generation method | Abu Taleb | Main CFD Forum | 0 | April 8, 2001 12:03 |
Data Structures for unstructured grid generation | Dinesh Godavarty | Main CFD Forum | 0 | December 5, 2000 10:49 |
