terminal velocity in spray dryer
Old   February 19, 2006, 16:23
Default terminal velocity in spray dryer
weekendwarrior
I am working on a problem involving spray dryers. The material to be dryed would be injected through a rotating nozzle with multiple openings from the top. Hot air would be blown from the dryer's bottom part. I was wondering how can I approach the problem to find out the particle's terminal velocity and how is terminal velocity related to reynolds number.any help will be appreciated.
thanks
Old   February 20, 2006, 00:47
Default Re: terminal velocity in spray dryer
diaw (Des_Aubery)
An interesting problem, indeed.
I would suggest considering the dynamics of the spray-head first. You will have a flowrate of liquid material into the head & so can determine an average exit distribution from the nozzles (assuming 100% distribution). I would imagine that the liquid would break up at some point away from the nozzle exit & travel on as slugs/prills of material. After that point, the prill dynamics would be reasonably straightforward.
The areas that could be of interest:
(1) Fluid distribution within the head - is it 100%, or biased?
(2) The fluid exit dynamics from the nozzle, before prill formation.
(3) The prill dynamics.
This kind of technology is well represented in the chemical industry & you may very well be able to answer some of your questions from Chemical-Engineering papers - before even moving into cfd simulation.
For example, fertiliser manufacture uses such atomising heads.
Sounds like a nice project. Enjoy...
Des Aubery
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
is there any method give node based velocity BC? daniel FLUENT 2 July 18, 2006 21:21
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Convection velocity of Coherent structures Jongdae Kim Main CFD Forum 3 February 5, 2002 04:04
