How to transform boundary condition from 3D to 2D?
Old   October 17, 2012, 23:23
Default How to transform boundary condition from 3D to 2D?
Nurul
nurul efha is on a distinguished road
Hello everybody,
I'm using CFD-Fluent to simulate gasification. In my case, mass flow rate that enter gasifier column is 0,0074 kg/s of coal. I want to simulate with 2D geometry. Only half of the domain with is modeled because of symmetry. Is it same the number of mass flow rate in 3D and 2D? Is the mass flow rate used in 2D unchanged (0,0074 kg/s)? Or the mass flow rate must be devided to transform in 2D? I hope you can help me. Thanks.
nurul efha is offline   Reply With Quote
Old   October 18, 2012, 08:45
agd
agd is on a distinguished road
The easiest approach is to compute the mass flux (mass flow/area) and then use that to determine what the mass flow rate would be on the modified inlet areas. In other words, scale the mass flow by the ratio of the areas.
agd is offline   Reply With Quote
Old   October 18, 2012, 21:51
Nurul
Thank you very much. I will try it.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
