Question about the characteristic length calculation
Like Tree4Likes
  • 1 Post By scipy
  • 3 Post By sbaffini
Old   October 21, 2012, 08:03
Question Question about the characteristic length calculation
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Hi
When we need to calculate the Reynolds number, we need to know the characteristic length firstly. May i ask how to calculate the characteristic length?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   October 21, 2012, 08:38
scipy's Avatar
Alex Pasic
scipy is on a distinguished road
Send a message via Skype™ to scipy
Characteristic length is the length of the obstacle in the flow field. The conventions vary from field to field so characteristic length can be: diameter of a cylinder around which fluid flows, length of a vehicle, length of the wheelbase of a vehicle, height of an obstacle etc. All in all, it's not really calculated, it's just a value you take as a factor because others years ago agreed on it.
In fact, most of the time it's listed on what is the Re based such as "Reynolds number in relation to the height of the barrier", or a similar quotation with "length" or "diameter".
manojkv likes this.
scipy is offline   Reply With Quote
Old   October 21, 2012, 15:00
Question
Anna Tian's Avatar
Meimei Wang
Thanks. I have fluid flow through a cube. The length l_x is 100. The width is l_y=10. The height l_z=0.01. The fluid flow at y direction. May I ask what's the characteristic length for calculating the Re?
Best regards,
Meimei
Old   October 21, 2012, 15:35
scipy's Avatar
Alex Pasic
If I've understood your problem correctly, you are interested in flow through a rectangular channel/pipe. In this case (and this only holds true for turbulent flow) you need to calculate the "equivalent hydraulic diameter" for which I've written the formula and drew a rough sketch in this picture:
http://i.imgur.com/ImM4g.png
I assume your units are meters (since they ought to be for calculating the Reynolds number), so just put in 0.02 in the Re=\frac{\rho v D_e}{\mu}.
This is the basis for Re calculation in non-round hydraulic calculation of pipelines and again, it's only valid for turbulent flows. Convetion is (as far as I'm aware) that internal flows with Re<2300 are considered laminar, period between Re 2300 and 4000 can be laminar but can easily transition into turbulent flow, and for Re>4000 you can almost be sure when you say it's fully turbulent.
Old   October 22, 2012, 09:01
Question
Anna Tian's Avatar
Meimei Wang
Thank you very much for your answer. It's very helpful! The unit is actually micrometer. One question: we need to know the characteristic length firstly, then we can calculate the Re. Then we can know if it's turbulent flow or not. If I don't know whether it's turbulent or not beforehand, shall I still use this formula to detect the regime of the flow?
Thanks!
Best regards,
Meimei
Old   October 22, 2012, 18:13
scipy's Avatar
Alex Pasic
You can use this formula, but if the calculated Re is below 2300 then the validity of the result is "questionable".
Old   October 23, 2012, 05:12
Question
Anna Tian's Avatar
Meimei Wang
It is below 2300. Is there a formula to calculate the characteristic length for laminar flow?
Best regards,
Meimei
Old   October 23, 2012, 13:34
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Just some facts:
Re is a non-dimensional number -> you just need to use consistent units. If the length is based on micrometers than you just have to add 1e-6 factor or use consistent units for the other quantities.
Re number and its effects exist independently from the state of the flow. For incompressible isothermal flows, Re number is the only parameter affecting the flow (actually you can define many of them based on different length scales). If for certain ducts with a certain roughness the transition is established around some Re number... well than that's it. You compute that Re number and, according to its value you know if you are turbulent or not. It's completely non sense to discard the Re number if it comes out to be below some treshold value.
At most, if it's in the transitional regime you can have some doubts about the flow being laminar or not, but the Re number is definetely remaining with the same value.
Hydraulic diameter is just a reference length. There is no way for it to become invalid in defining a Re number just because it comes out too low.
Bai Hu, soheil_r7 and soriyoshi like this.
sbaffini is offline   Reply With Quote
Old   October 23, 2012, 17:10
Question
Anna Tian's Avatar
Meimei Wang
My purpose is to know whether my flow is laminar or turbulent. Do you mean i can completely use hydraulic diameter as the characteristic length to calculate Re to know my regime?
Originally Posted by sbaffini View Post
Just some facts:
Best regards,
Meimei
Old   October 23, 2012, 18:36
sbaffini's Avatar
Paolo Lampitella
Long story short: YES.
More correct way to express my way of thinking: "if you have some rule (based on experimental evidence or whatever) which tells you that, for a certain flow, when Re (based on a certain length, which can be the hydraulic diameter, it usually is but depends on the rule) is below some number then the flow is laminar" that rule is necessarily valid for all the values which can possibly come out from the Re number defined above.
Does this sentence makes sense to you: "if Re is above X the flow is turbulent, otherwise i don't know"?
And this one:" if Re is above X the flow is turbulent; if Re is below Y the flow is laminar; if Re is between Y and X the flow is transitional"?
If the last one makes sense to you (i hope so), do you expect the "Re" appearing in it being defined always in the same way all the times it appears in the sentence, or i should have written something like:
" if Re1 is above X the flow is turbulent; if Re2 is below Y the flow is laminar; if Re3 is between Y and X the flow is transitional"?
I imagine my point is clear now.
Going to your problem, that rule of thumb exists for duct flows and is based on the hydraulic diameter. Do i expect it to be accurate enough independently from the real shape of the duct section and its roughness? Hell no, it's a rule of thumb based on pure experimental evidence, not a theory.
Old   January 20, 2013, 14:15
Question
  #11
Anna Tian's Avatar
Meimei Wang
Thank you. May I ask you another question?
If I have a very complex geometry and I have no experience about the relation between Re and the flow regime, then how to decide whether laminar model, or turbulent mode, should be used for this case?
Thank you very much!
Best regards,
Meimei
Old   August 2, 2019, 05:40
Unhappy Characteristic length for a narrow aerodynamics
  #12
Owais Shabbir
Owais Shabbir is on a distinguished road
Dear All,
I am trying to simulate turbulent flow over the solid which has vertical slits present. After reading this thread I understood it should be the length of the obstacle but what if the obstacle has some gaps present in between it and my domain is very tight.
I run simpleFoam and the case works nicely with kEpsilon model but with turbulence turned off.
I am attaching my domain and their views. Please help me I am really stuck with this and I have very little time to finish this project.
I have tried following characteristic lengths:
1. length of the complete solid
2. inlet length
3. height of the front solid.
Simulations always crashes. the residuals go above 1 and the epsilon diverges.
Any help would be appreciated.
Best Regards.
Last edited by Owais Shabbir; August 2, 2019 at 07:45. Reason: forgot the attachments
Owais Shabbir is offline   Reply With Quote
Old   August 2, 2019, 05:47
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Anna Tian View Post
Hi
There is no unique choice. The characteristic lenght depends on the flow problem: a chord for an airfoil, the diameter for a cylinder, the step height in a backward facing steps flow are geometrical lengths. But in free flows the lenght is an intrinsic characteristic of the flow (boundary layer lenght, Taylor micro-scale, etc)
FMDenaro is offline   Reply With Quote
about L-J Characteristic Length KEVIN FLUENT 11 December 6, 2018 13:16
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 03:51
characteristic length maryam FLUENT 0 January 10, 2004 01:22
Characteristic Length CFD MAN FLUENT 0 August 19, 2002 21:40
Characteristic Length Scale Thomas P. Abraham Main CFD Forum 2 April 20, 1999 17:16
