[Sponsors] | |||||
What is the difference between galerkin and discontinuous galerkin methods.
Classic Galerkin enforce continuity from one element to the next one. In each node, a variable has a unique value. If you use linear elements, there is continuity of the variable solved for, but not of its derivative. Using higher order elements, you can enforce that.
Discontinuous Galerkin doesn't enforce such continuity between elements. The method allows for different values in neighbouring elements at the same physical location. Usually though, for good accuracy, the jump across an interface is (very) small. In the end there has to be a way to couple the solution in the different elements, this is done by solving a Riemann problem. |
What paper you may offer for the first acquaintance?
A good introduction would be the online course of Tim Warburton. http://www.caam.rice.edu/~timwar/MA578S03/MA578.html
If you want a single file to look at you read the notes from Bernardo Cockburn. http://www.math.umn.edu/~cockburn/LectureNotes.html Both are DG experts. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fluent UDF Discontinuous Motion | lequi7 | Fluent UDF and Scheme Programming | 2 | November 4, 2011 00:18 |
| Discontinuous Galerkin schemes -- fortran source code | diedro | Main CFD Forum | 3 | March 12, 2011 11:20 |
| Discontinuous Galerkin method | Troy | Main CFD Forum | 1 | October 29, 2007 04:27 |
| discontinuous contour for internal wall? | Orca.Fight | CFX | 1 | August 17, 2005 11:40 |
| Discontinuous Galerkin finite element method | Tony | Main CFD Forum | 0 | May 27, 2003 19:48 |
