Core size in VEM
Old   July 26, 1999, 05:17
Default Core size in VEM
Jerome
I am using a regularized vortex element method to study wakes behind aircrafts but I have a problem with the choice of the core size of regularization: the cores of particles have to overlap and is then of the order of the mean inter-particles distance but my vortex sheet is likely to be torn between flaps, but the method cannot foresee that, and so to my mind, I can't take into account directly the mean inter-particles distance.
Can anybody help me?
Old   July 26, 1999, 09:51
Default Re: Core size in VEM
olus boratav
The following references might help.
Knio and Ghoniem (1990)
Numerical study of a 3D vortex method
J. Comput. Phys, 86, pp.75-106
Fernandez, Zabusky, Gryanik (1995)
Vortex intensification and collapse.....
JFM 229, pp.289-331
Pelz (1997)
Locally Self-similar, finite-time collapse in a high-symmetry model
Phys. Rev. E. 55(2), 1617-1626
Olus Boratav
Old   July 26, 1999, 14:22
Adrin Gharakhani
I don't see a significant problem with the vortex sheet spliting around the flaps. That is if you use discrete (disjoint) elements and not the vortex filament model (where the elements are assumed connected).
The core overlap condition is really a confusing criterion! Basically you'd want the core of an element to overlap the core of the nearest neighbors. If a stream of elements reach a "bifurfaction" such as the flap, then the particles within each stream would have to maintain their respective core overlap. In practice, and unless you have significant vorticity stretch, you hardly have to worry about core overlap if you have small enough of a timestep (as overlap would generally be satisfied if it was satisfied initially). You can check the validity of the above statement by post-processing the relative positions of the elements. As for the case with stretch, there are issues just as important as core overlap that you need to consider and worry about (and it is beyond the scope here)
Adrin Gharakhani
Old   July 27, 1999, 03:42
Jerome
I understand what you mean but my aim was to fix the value of the core size in order not to give it arbitrarily so that I can find the same results as experiments. That's why I wanted to use the core overlap condition. In the main part of the computation, the core overlap is satisfied elsewhere but not between flaps where the stretch remains to high, hence my question: I have to give a value of the core size but how?
Hopping that I was clear,
Jerome
Old   July 27, 1999, 15:29
Adrin Gharakhani
Well, the core size is an arbitrary variable (no ifs or buts about it) - in a sense it's similar to (but not exactly the same as) grid size in grid-based computations. Larger core sizes will give you more diffuse results, and convergence occurs (presumably) in the limit of zero core size (much like grid size).
I still don't see why you should worry (too much) about the flap region. You should just make sure that the cores don't cross the flap (that will lead to a misrepresentation of vorticity). Thus, so long as the cores don't cut through the flap and you have core overlap you're safe. If the cores do cut the flap, say at a sharp leading edge, I'd say the effect of this is similar to rounding the sharp edge. The rest is a matter of "convergence study"
Check out the JFM paper by Marshall et al (within the last 3 years or so) which is a vortex simulation of a 3D vortex ring cutting through a blade. This is quite similar to what you're doing - the difference is that in the JFM paper the blade does not generate vorticity (flow about it is inviscid)
Adrin Gharakhani
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
