k-e boundary conditions
Hi friends
I am working on a FVM code using k-e turbulence model for a simple channel flow I have some confusion over the application of Boundary conditions for k and epsilon and also after first complete iteration for one timestep how to use extract the fluctuating components of the velocities and how to use them for next timestep itertions i am in urgent need please help me friends thank you friends for help bye Ravi Kiran |
Re: k-e boundary conditions
Which aplication u r using, For ur kind I would like to give the following, for k-e model you can give K=(u**2+v**2+w**2)/0.5 as one and you can give L=0.3*H as another boundary condition. These were rough calculations, if u have any experimental values its better.
Thank you shashi
I am trying to simulate Bounday Layer on a pate with k-e model and a channel flow with k-e model so the above two i know how to specify k at wall, just above wall in the FVM code which i am trying to develop and also how to estimate the fluctuating components of velocities from k how to use these fluctuating components for next iterations if u or any one could explain thank you i am in vey urgent need of this data ok bye Ravi Kiran |
