How to calculate swirl without using swirl generators
Old   November 21, 2012, 23:28
Default How to calculate swirl without using swirl generators
srinivasan
drsrinivasan is on a distinguished road
Sir,
I am working on simulation of combustion process in axial flow gas tubine combustor. The main reference journal paper has s 2-D model and no information about the swirler. They have solved for swirl number 0.37,0.76 and 1.2. The air inlet ratios are as follows
primary(axial):secondary(axial):dilution(axial) as 5:7:8. Now, I am looking forward for a method to calculate swirl. Is there any formula/method to calculate swirl in terms of velocities. I request you to help me.
drsrinivasan is offline   Reply With Quote
Old   November 22, 2012, 03:06
Rami Ben-Zvi
Rami is on a distinguished road
I believe the swirl is defined (in tensor notation) as 2Wik=Ui,k - Uk,i (where Ui is the velocity vector and "," denotes covariant derivative), i.e., the antisymmetric part of the strain rate tensor. In 2D x-y plane flow the only non-zero Wik's are Wxy = -Wyx = (Ux,y-Uy,x)/2.
Rami is offline   Reply With Quote
How to calculate swirl velocity hamoudi STAR-CCM+ 2 March 2, 2015 13:25
How to calculate the SWIRL NUMBER David FLUENT 1 January 6, 2013 01:23
How can I calculate Swirl number at different heights in a column mali28 FLUENT 4 December 3, 2012 15:08
How to calculate swirl velocity hamoudi FLUENT 0 June 13, 2009 10:30
How to calculate inlet swirl number in Post? CFXPostuser CFX 8 April 29, 2009 13:50
