November 30, 2012, 16:25 |
K - epsilon VS SST turbulence model
Michele
Hello everybody,
I made the cfd model with three domain, two fluid domains and one porous domain. at the inlet section I put an average pressure and a mass flow rate at the outlet section. I run the simulation using a k-epsilon model: the results regarding turbulence kinetic energy showed very high values, so i tried to run a model with SST turbulence model. I had to have a finer mesh with this last turbulence model, so i made a model with just one fluid domain and I used the velocity flow field, turbulence kinetic energy and turbulence eddy dissipation obtained with previous model in corrispondence of interfaces with other domain: the results for turbulence kinetic energy wery mush lower than the previous one (absolutely not comparable). I made a further check: I used the same model I described for SST model, but changing the turbulence model to k espilon: I expected similar results to the first model I ran, but turbulence kinetic energy was much lower respect to first model (and a little higher than values obtained with SST model): so, what do you think it's wrong with that?? Thank you so much! |
boundary and initial condition for SST k-omga turbulence model | mb.pejvak | Main CFD Forum | 3 | May 1, 2012 20:06 |
Turbulence Model and limitation to Reynolds number | qascapri | FLUENT | 0 | January 24, 2011 10:48 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Sinclair Model + secondary turbulence | Yi | FLUENT | 0 | October 26, 2001 13:37 |
