March 19, 2006, 19:55 |
Patankar's cyclic TDMA
Hi everybody! Does anybody has the subroutine of the cyclic TDMA of Patankar?Can you send me it? Thank you in advance
March 20, 2006, 20:17 |
Re: Patankar's cyclic TDMA
Or any other subroutine concerning cyclic or periodic boundary conditions...
March 20, 2006, 22:40 |
Hi, If it is TriaDiagonalMatrixAlgoritm, you can find it Numerical Recipies in FORTRAN or Numerical Recipies in C.
March 21, 2006, 02:55 |
i have a TDMA subroutine. but what you mean by cyclic. if it is a slice from axisymetric 360 degrees. please explain it.
March 21, 2006, 11:49 |
Yes, it is a TriaDiagonalMatrixAlgoritm.But if there are cyclic or periodic boundary conditions in the flow, then there is a different version.I am trying to change it, but I have some problems. For Ali Mottalea: It is not axisymmetric, it is full 3D cylindrical flow.
March 21, 2006, 14:08 |
ok. then as i know your coordinate system is cylindrical and in teta=0 and 360 you have cyclic condition. is it true?
March 21, 2006, 19:10 |
Yes. And you must change a little bit the original TDMA, so that you can take into consideration this difference in the usual boundary conditions
March 22, 2006, 10:18 |
For symmetric tridiagonal matrices (diagonally dominant) you can give a look here:
http://www-dinma.units.it/nirftc/research/cyctrid/ |
Cyclic bc. and overlapGgi | Pekka | OpenFOAM | 12 | February 15, 2012 07:10 |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
Cyclic patches and parallel postprocessing problems | askjak | OpenFOAM Bugs | 18 | October 27, 2010 03:35 |
[snappyHexMesh] snappyHexMesh with cyclic patches? | Axel_T | OpenFOAM Meshing & Mesh Conversion | 1 | October 12, 2010 10:03 |
