Weird artefacts ... mesh-problem?
Old   December 12, 2012, 01:47
Default Weird artefacts ... mesh-problem?
Eike
Eike is on a distinguished road
I get some weird artefacts like dents and rows ... is ther e anyone who has seen this before?
There is a constant mesh (Trimmer 20x20x20mm) with prism layers, do I have to refine it? The velocity of the fluid is around 0.1 to 0.3 m/s and I use a timestep of 0.025s at 8 iterations. I'm using k-omega SST ...
Best wishes
Eike
Eike is offline   Reply With Quote
Old   December 12, 2012, 09:27
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
let me guess: big triangular mesh without boundary layer in tat area and your mesh does something like this
_ _ _ _ _ _ _
i'd say that this is beacause one edge of the triangule touch the wall and the next cell have one whole face on the wall.
maybe interpolation issues? you might try to reduce this behaviour using higher order schemes.
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   December 13, 2012, 11:00
Eike
The mesh is cubic 20x20x20mm with prism layers at the walls ...
Wall Y+ varies at these spots:
This are some plane sections cutting the spots, scalar is velocity:
Old   December 13, 2012, 14:57
Martin Hegedus
Martin Hegedus is on a distinguished road
I've seen this sort of problem for low Mach number flows when a compressible solver without Mach number preconditioning is used. But, if you are using an incompressible solver than this is not an issue. I've also seen this sort of issue when not enough artificial damping is used with a central difference method.
Martin Hegedus is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 20:26
