Design of compressor cascades
Old   May 3, 2012, 00:54
Default Design of compressor cascades
Manu Kamin
manukamin is on a distinguished road
Hello
It is my intention to design a cascade of airfoils which represents its corresponding axial flow compressor.
What I want to know is what are the design inputs to be considered for this particular task. For example is it the outlet to inlet pressure rise ratio or it the rpm of the rotor or is it the axial velocity that is to be considered as my design input according to which I define parameters such as blade profile, spacing between blades etc.
Could someone please let me know how I have to approach and where I cold find the necessary literature?
Regards
Manu
manukamin is offline   Reply With Quote
Old   December 5, 2012, 00:20
Manu Kamin
Hello
Well I got a lot of information on axial compressor design in a book named "Aircraft Engine Design" by J.D.Mattingly. I suggest you check it out as well.
Old   December 5, 2012, 05:30
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
Originally Posted by manukamin View Post
Hello
Regards
Manu
For simulating an axial compressor you need to have the Aero-thermodynamic properties such as compressor map which represent the head and flow coefficient so you can calculate the inlet and outlet, pressure and the mass flow rate, and the blade profiles. You can easily find many test stages and their setup and use it. The inlet total and static pressure is needed to be set as inlet boundary, the outlet static pressure is needed to be set as outlet boundary. the rotor speed is needed to be set as the rotor passage revolution. With these parameters you will be able to do the job.
Regards.
vicarious is offline   Reply With Quote
Old   December 19, 2012, 00:03
Manu Kamin
Hi Vicarious
Thanks a lot for the reply.
Manu
Old   December 19, 2012, 00:14
Manu Kamin
But then again, another doubt arises. How can you impose a pressure at the outlet as a boundary. Don't you think I should allow the flow to develop and see what pressure is attained rather then impose a pressure at the outlet?
Old   December 19, 2012, 14:42
vicarious's Avatar
Pedram Mojtabavi
There is not any alternative and appropriate boundary other than pressure for such devices I'm afraid. Compressors work at a specific pressure rise corresponding to its mass flow. So in theory you achieve a pressure rise that you cannot achieve in numerical solution or experiment. You use these values to initialize your solution and reach close to them by solution. Other boundary definition will result in wrong answer or will not work.
Regards.
Old   December 19, 2012, 23:25
Manu Kamin
Oh I see. Thanks for the response.
Regards,
Manu
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
star design - to model heat transfer gagi Main CFD Forum 0 November 11, 2011 01:41
JOB: Sr. Thermal/Mechanical Design Engineer Dee Dee Dial Main CFD Forum 0 April 1, 2003 18:49
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
CFD - Trends and Perspectives Jonas Larsson Main CFD Forum 16 August 7, 1998 16:27
