calculate k and epsilon from turbulent intensity
Old   March 22, 2006, 06:47
Default calculate k and epsilon from turbulent intensity
Ralf Schmidt
Hi there,
I want to calculate the inlet parameters for k and epsilon from my experimental results u', v' and w' or Turbulent intensity Tu.
How can this be done?
Ralf
Old   March 22, 2006, 06:50
Default Re: calculate k and epsilon from turbulent intensi
Ralf Schmidt
I found some eq. in the forum, but does someone know, were they are from? And for what they are valid???
Mu_eff=20*Mu_laminar
k_inlet= (U_in*TU)**2
Tu=turbulent intensity.
U_in=sqrt(u*u+v*v+w*w)
e_inlet= (Cmu*rho_inlet*(k_inlet)**2)/Mu_eff
Old   March 22, 2006, 16:52
Jonas Larsson
The non-general part on those formulas is the Mu_eff=20*Mu_laminar equation, that is just a wild guess. It might be a fairly okay for external aerodynamics where the turbulence level coming in is very low, but for internal flows with more turbulence Mu_eff will be much higher. Then it is more correct to try to estimate the turbulent lenght-scale and derive epsilon from that. You can find the formulas in any book about turbulence modeling. I'd recommend Wilcox's Turbulence Modeling for CFD. If I get some time tomorrow I'll try to add the relevant formulas to the Wiki here so that you can get them directly online. If someone has them in latex already feel free to help me.
Old   March 23, 2006, 10:25
Jonas Larsson
I just wrote something about the turbulence intensity in CFD-Wiki here:
http://www.cfd-online.com/Wiki/Turbulence_intensity
Someone should add something about turbulent lengths scales, viscosity ratios etc. also. I'll see if I get some time later to do this also.
Old   March 23, 2006, 17:05
Jonas Larsson
I also wrote something about the turbulent length-scale here:
http://www.cfd-online.com/Wiki/Turbulent_length-scale
Old   March 23, 2006, 21:15
Frank Smith
hello... For a diffuser with outlet/inlet area ratio of about 5, what value would you suggest for turbulent length scale? Thanks.
Old   March 24, 2006, 05:50
Jonas Larsson
That depends entirely on what is upstream of the diffusor.
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
BC Profile with Turbulent Intensity blackbody CFX 1 May 13, 2010 07:10
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
How CFX calculate TKE and Epsilon from intensity? David CFX 0 November 24, 2005 04:53
