Why switching time step length can help on achieving the convergence
Old   December 27, 2012, 17:17
Question Why switching time step length can help on achieving the convergence
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Hi
When my simulation doesn't converge, I always change my time step to a smaller time step(or larger time step). Then after a lot of iterations, it still doesn't converge. Then I switch the time step back to what I used at the beginning. Then my simulation converges.
Could you tell me why switching time step(and then switch back) can help on the convergence? How do you explain this theoretically?
Thank you!
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   December 27, 2012, 17:43
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I am assuming you are referring to steady state simulations and that you are using timestepping for stability. Correct me if I'm wrong. Smaller timesteps make things change more slowly, making it less likely the solution will diverge or get into a situation where convergence gets stuck. However a smaller timestep will mean it will take longer to achieve a steady state solution. Thus it can be helpful to start with a small timestep to get things going in the right direction and them change to a larger one so it can actually reach steady state in a reasonable length of time.
cdegroot is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Time step, Number of time step, Maxximum Iterations per time step sandisk FLUENT 0 July 18, 2011 02:57
