PISO for high Courant Numbers
Old   April 18, 2006, 17:13
Default PISO for high Courant Numbers
turb
1) Can PISO be used in transient simulations with a high Courant Numbers (say, >20)?
2) Can it be stable (with a lot of inner iterations -> is that all I need)?
3) is it more stable than SIMPLE for these cases (transient, but with a high Courant)?
4) good references?
Thanks a lot.
Old   April 20, 2006, 11:42
Default Re: PISO for high Courant Numbers
newposter
The original version of PISO was developed for transient calculation with small timesteps, so you have also small Courant numbers (<1) in this non-iterative variant. If you are running PISO like SIMPLE with outer Iterations you do not need small Courant numbers, but the convergence rate of PISO will then not be better or faster than SIMPLE! See also the paper "Solution of the implicitly discretised fluid flow euqations by operator splitting" by R.I. Issa!
Good Luck!
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Small influence of convection in PISO if Courant number is small sebi OpenFOAM 0 February 22, 2011 14:55
How to fix slowly increasing Courant numbers ploceus OpenFOAM Running, Solving & CFD 6 June 15, 2009 04:00
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
