April 18, 2006, 17:13 |
PISO for high Courant Numbers
1) Can PISO be used in transient simulations with a high Courant Numbers (say, >20)?
2) Can it be stable (with a lot of inner iterations -> is that all I need)? 3) is it more stable than SIMPLE for these cases (transient, but with a high Courant)? 4) good references? Thanks a lot. |
April 20, 2006, 11:42 |
Re: PISO for high Courant Numbers
The original version of PISO was developed for transient calculation with small timesteps, so you have also small Courant numbers (<1) in this non-iterative variant. If you are running PISO like SIMPLE with outer Iterations you do not need small Courant numbers, but the convergence rate of PISO will then not be better or faster than SIMPLE! See also the paper "Solution of the implicitly discretised fluid flow euqations by operator splitting" by R.I. Issa! Good Luck! |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Small influence of convection in PISO if Courant number is small | sebi | OpenFOAM | 0 | February 22, 2011 14:55 |
How to fix slowly increasing Courant numbers | ploceus | OpenFOAM Running, Solving & CFD | 6 | June 15, 2009 04:00 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
