Ansys
Old   May 18, 2006, 21:23
Default Ansys
srinivas
I am trying to simulate flow over an airfoil in ansys 8.0. But, i also need to simulate conduction simulatneously within the airfoil as there is an internal heating process. I need to mesh outside the airfoil using quad elements and triangular elements within the airfoil. Both quad and tri element types are of diff material numbers. I face a difficulty in generating two grids and assigning them diff material numbers.
Kindly help me. Thanks in advance
Old   May 22, 2006, 07:56
Default Re: Ansys
Iles Amel
J'ai un logiciel Ansys version 8.0, je l'applique pour calculer des grandeurs électromagnétiques pour des résonateurs utilisés en IRM. En utilisant le module des hautes fréquences (HF) je ne sais pas comment trouver les constantes primaires R, L, C et G Ã partir d'un cahier de charge donné. Mes remerciements.
Command Line Run for ANSYS Liaquat ANSYS 11 April 19, 2018 09:49
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 12:11
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
