problem in running FoamX in Open FOAM
Old   May 10, 2006, 04:29
Default problem in running FoamX in Open FOAM
Gaurav
I have installed Open FOAM V1.3 on my machine but I am not able to run FoamX. It shows me the error described below:
[vasu@ltrac-22 vasu-1.3]$ FoamX Starting NameServer with inet:ltrac-22.eng.monash.edu.au:1234 ... nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory
Can any one help me? Thanks in advance.. Cheers
Old   May 10, 2006, 05:10
Default Re: problem in running FoamX in Open FOAM
Gaurav
I did it just install library libelf.so.0 and there you go... Good on me. Cheers
Old   May 10, 2006, 05:45
Mac
FYI: You're posting in the wrong forum. Openfoam queries go here -> http://openfoam.cfd-online.com/cgi-bin/forum/discus.cgi
Old   May 10, 2006, 06:06
Gaurav
oh sorry my fault ...
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 05:18
[Commercial meshers] Problem in running mesh imported from fluent to foam vishal OpenFOAM Meshing & Mesh Conversion 2 February 6, 2009 11:05
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
