Validation Case for Pulverized Wood Combustion
Old   May 14, 2006, 12:29
Default Validation Case for Pulverized Wood Combustion
Robert Scharler
after a long and unsuccessful search I would like to ask if anyone knows about reliable data on measured pulverized wood flames (temperature, CO etc.). We need this urgently for CFD model validation.
Thanks.
Old   May 15, 2006, 17:34
Default Re: Validation Case for Pulverized Wood Combustion
Allan Walsh
At a recent conference, I saw a paper on a Saacke dust burner with some limited data on CO and NOx. You might contact them for more information.
I have also seen a fairly old paper from Coen on a sanderdust burner with global results. Good luck.
COMBUSTION TEST CASE Banaeizadeh Main CFD Forum 1 December 17, 2004 11:05
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
Validation case for fluid/solid interaction Raj Main CFD Forum 0 July 11, 2003 15:39
gas combustion test case Tomasx Ochrymiuk Main CFD Forum 2 June 20, 2000 02:42
Heat Transfer Validation test case Chris Whitney Main CFD Forum 1 July 21, 1999 14:36
