SIMPLE pressure correction in compressible flows
Like Tree1Likes
  • 1 Post By Maarten de Jong
Old   May 25, 2002, 16:42
Default SIMPLE pressure correction in compressible flows
Maarten de Jong
I have been using CFD on incompressible flows for quite a while now, and have recently began studying compressible flows. One thing about these puzzles me considerably. In some of the books and codes I have studied (for example, 'Computational Methods for Fluid Dynamics' by Ferziger and Peric), a modified SIMPLE-pressure correction method is used. I was under the impression that you need SIMPLE or its brethren in incompressible flows because you do not have an expression to compute the pressure field (and subsequently, its gradient). In compressible flows, you have an equation of state which relates density to pressure. (See for example on page 159 of the aforementioned book, and compare to page 293.)
Can someone please explain why you would want to use SIMPLE-like pressure correction in compressible flows?
granzer likes this.
Old   May 25, 2002, 21:20
Default Re: SIMPLE pressure correction in compressible flo
Jim Park
Not sure about the SIMPLE family, but the classic work at Los Alamos used a pressure correction field in incompressible problems to make sure the advanced-time velocities solved the continuity equation.
As you are aware, the pressure can sometimes be eliminated altogether from an incompressible problem, solving instead for the stream-function vorticity or even the stream function only [via a 4th order PDE]. For good reason, these tactics have been more popular in two-dimensional (space) than three-dimensional space.
Old   May 27, 2002, 08:26
Seb Perron
1) As you wrote, In compressible flows, you have an equation of state which relates density to pressure and temperature. Hence you do not need any special algorithm (or projection step) to compute the pressure field.
2) But, there can be three advantages using a projection step (such as in the simple family of schemes or in Chorin's projection's methods), even for compressible flows:
a) the projection step tends to stabilize the scheme;
b) with a projection step and cell centered FVM methods, you can make sure that the velocity field near walls agrees with the boundary conditions right at the begining of the solution process;
c) the scheme can be used for both compressible (not hypersonic) and incompressible flows.
3) There might be one desanvantage: I'm not sure that projections methods are efficient when a entropic solution is sought (i.e. get the right speed of displacement of a shock).
Good luck.
Old   June 5, 2002, 23:40
mukkarum
Sir i am working on research project "revemping of Francis Turbine applying CFD". I have got book "An introduction to computational fluid dynamics (finite volume) by malalasakra" it is very good book and i have understand SIMPLE, SIMPLER AND SIMPLEC method of solving Navier Stock equation but in this book just presentation that how Navier Stock equation can be solved but there is no solve example. Do you know any book or article in which this type of example is present. I mean that for any given problem(good if turbine rotor)firstly assume pressure field and then find velocity field then check pressure correction equation and repeat this procedure still convergence occure. waiting for your prompt reply thanks
Old   June 15, 2011, 12:54
akj
anil
akj is on a distinguished road
Originally Posted by mukkarum
;20128
u better refer patankar for problem on SIMPLE alogrithm...because he was d guy who actually gave this therory...
akj is offline   Reply With Quote
Old   June 15, 2011, 12:55
akj
anil
Old   April 30, 2012, 02:22
Dr. Madhukar M Rao
madhukar_m_rao is on a distinguished road
You may want to use the SIMPLE family of algorithms for compressible flows, if:
[1] you already have a well tested and reliable flow solver for low Mach number
flows that you now want to extend to high speed flows.
[2] bulk of the flow domain has flow at low Mach number.
madhukar_m_rao is offline   Reply With Quote
Old   April 30, 2012, 02:23
Dr. Madhukar M Rao
See 2nd edition of Veersteg and Malasekhera. It has examples for the SIMPLE algorithm.
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 12:45
pressure correction in compressible flow Yijin Li Main CFD Forum 1 January 10, 2009 08:04
Pressure correction in Buoyancy driven flows Aditya Main CFD Forum 0 March 8, 2007 06:36
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 16:14
