torque shatf & power shaft
Old   April 18, 2013, 06:48
Unhappy torque shatf & power shaft
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hi!
Im not an air fan expert and i`d like some tips. I have a fan modeled in a closed circuit which is somewhat being constricted past the fan, hence the pressure increaeses a little more. So the pressure difference is higher than the dynamic pressure only. Inlet is atmospheric. A mrf model of my fan alone in a environment, using MRF models, shows a mass flow rate of 12-13 kg/s of air at 2500 rpm. a second modeling, without MRF, but with boundary conditions simulating the flow from the fan (w/o swirling) an average surface pressure of 3400Pa results past the fan!
With some simple formulas i have:
shaft power as : massflowrate*deltaP
                         12.8*3425 = 43520W
shaft torque as:  shaft power/ 2*pi*N   , where N = revolutions per sec
                          60*43520/2/3.1416/2500 = 166Nm
i ask, is the math correct? arent these values a little too high for an 600mm diameter fan? do i have to attach a 1L car engine to keep up this fan rotating in this system?
any comments are mostly welcome!
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Torque Converter Pump Torque = Engine Torque? Torque_Converter Main CFD Forum 4 November 12, 2012 06:44
shaft power versus RMP curve in wind turbine simulation zhenduan306 CFX 28 November 8, 2012 10:11
Torque valuation on the shaft of a VAWT Skywalker Main CFD Forum 0 August 28, 2011 08:32
about use macro to compute torque in TASCflow lancy CFX 0 June 10, 2003 06:19
