August 19, 1999, 20:59 |
Boundary Condition in PISO
Hello, I'm developing an incompressible flow code using 'PISO' algorithm but I cannot find appropriate boudary condition. Is there any special boundary condition for 'PISO' algorithm(Especially for pressure correction equation)? I implemented pressure correction equation to 2nd correction step, but in comparison with SIMPLE method, the 2nd correction was not effective so I see the 2nd correction step implementation has some problem with boundary condition. If you have any advice, thank you for your answer. Have a nice day.
August 20, 1999, 13:24 |
Re: Boundary Condition in PISO
Boundary conditions are not easy to implement with PISO. For the pressure Poisson equation you can get a boundary condition (Neumann type) by writing the normal component of the momentum equation on the boundary (using of course the chosen boundary conditions for velocity). Then you must introduce an additional relation which allows you to get rid of the unknown term involving the velocity corrections in this equation. You can set this term equal to zero or extrapolate it from the interior nodes.
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Can anyone give me some hint on how to make traction free boundary condition? | poplar | OpenFOAM | 3 | January 14, 2015 02:37 |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
