June 16, 2006, 11:58 |
3D lid validation data
hi all
I've developed a 3D incompressible N-S solver and I've solved the 3D lid driven cavity problem. now I want to validate my results. I need the datas like center line u,v,w velocities for Reynold's number 100,400,1000,3200,5000 n 10000. I request you all to help me in getting the data or the link from which i can download the data. if you've the datas you can mail me too.. ashook_j@rediffmail.com with regards |
June 16, 2006, 13:38 |
Re: 3D lid validation data
June 16, 2006, 14:38 |
Take a look at the following articles:
R. N. Elias, M. A. D. Martins, A. L. G. A. Coutinho, Parallel Edge-Based Inexact Newton Solution of Steady Incompressible 3D Navier-Stokes Equations, Euro-Par 2 sept 2005, Lisbon, Portugal R. N. Elias, A. L. G. A. Coutinho, M. A. D. Martins, R. M. Sydenstricker, Edge-based Data Structures for the Parallel Solution of 3D Steady Incompressible Fluid Flow with the SUPG/PSPG Finite Element Formulation , XXVI CILAMCE - Iberian Latin American Congress on Computational Methods - Out/2005, Guarapari, ES, Brasil they're available to download at: http://www.nacad.ufrj.br/~rnelias/pubs.html I wrote these articles last year and I'll try to find my output data files in order to send you. The subject is not directly related to lid driven study and I only used this case to validate my program. Therefore, you'll only find some validation plots and some other references. Cheers Renato. |
June 16, 2006, 15:59 |
Thanks renato... plz do send me those data files..
validation data for high pressure transient gas injection | doki | FLUENT | 0 | September 26, 2010 10:48 |
Validation of wind turbine simulations using experimental data of much lower Re | Dorit | Main CFD Forum | 0 | March 31, 2010 05:20 |
Import validation data to CFX Post | Vattenkraft | CFX | 0 | November 26, 2009 19:55 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
experimental data for code validation | Ambrose | Main CFD Forum | 4 | May 4, 2004 14:33 |
