Re: which is a better way to loop in fortran?
Old   June 24, 2006, 22:56
Default Re: which is a better way to loop in fortran?
zonexo
Tks for your suggestion Tom, but what if i need to multiply by 2 for some values of i, but 10 for some other values. it's something like this:
integer multi(10) for i=1,2,7,9, multi(i)=1
do j=1,10 do i=1,10 if (multi(i)=1) then
a(i,j)=2*i*j else
a(i,j)=10*i*j end do end do
of cos, values of i/j are very small. but in reality, i,j can be 100 or 1000. in this case, will changing the innner loop to a(i,j)=(1-multi(i))*10*i*j + multi(i)*2*i*j be better?
i can't think of a better way.
for others a(i,j)=10*i*j. Normally, i would use a logical variable multi(10), where multi(1)=.true. for the 1st case, .false. for 2nd case.
Here's just an example, but in
Old   June 25, 2006, 10:40
HelpfulSoul
I would have thought that holding the coefficients 2 and 10 in the multi() array and simply using
DO i=1,10 DO j=1,10
a(i,j)=multi(i)*i*j END DO END DO
would be better as it avoids the branch statements of your first bit if code and avoids the extra arithmetic of your second bit of code.
Old   June 25, 2006, 15:12
Adrin Gharakhani
Now that you've gone this far in simplifying you can go one step further and actually assign multi(i) = c*i, where c is your conditional constant (2, 10, etc.). This is an O(N) process. Now you can write the code as
Do j=1,10; Do i=1,10; a(i,j)=multi(i)*j; enddo; enddo
Adrin Gharakhani
Old   June 25, 2006, 16:19
HelpfulSoul
and the multiplication can be eliminate completely with
a(:,1)=multi(
DO j=2,10 a(:,j)=a(:,j-1)+multi( END DO
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
which is a better way to loop in fortran? zonexo Main CFD Forum 7 June 23, 2006 05:47
Big loop problem of fortran Wen Long Main CFD Forum 9 April 1, 2004 13:38
