June 17, 2006, 11:16 |
Skewness angle
Hello everybody,
what is the commen definition of a skewness angle of a tetrahedron? I looked for this for hours and can't find an answer. Thanks for reading, Chris |
June 20, 2006, 22:28 |
Re: Skewness angle
For 2D Tria, the property that might grasp our interest is the skewness angle, defined by HM:
skew in Trias is calculated by finding the min. angle between the vector from each point (of the Tria) to the opposing mid-side and the vector between the two adjacent mid-sides at each point of the Tria. For 3D Tetra, volumetric skew is important, defined by HM: A sphere through the four nodes of the tetra is created. That sphere defines an ideally shaped equilateral tetra, in which its volume is defined as: 8r^3/(9*sqrt(3)). The actual volume of the tetra element is then determined. The Tetra's volumetric skew is then written as: Volumetric skew =( Videal-Vactual)/Videal Hope that helps. -khai ching- |
June 21, 2006, 09:09 |
Re: Skewness angle
Ok, so I guess the term "Skewness angle" does not exist. I am examining a volumetric grid in Gridgen with that "Skewness - min ang"-Function and wonder which angles are meant. The overall average of those angles is around 45°.
June 21, 2006, 09:15 |
Re: Skewness angle
probably the angle between two adjacent edges, or the angle between an edge and the two faces it is not part of ...
June 24, 2006, 15:36 |
Re: Skewness angle
Chris, I suggest that you contact a technical support engineer at support@pointwise.com and they will be able to tell you exactly how that skewness measure is calculated.
Display Modes | |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 18:24 |
Theoretical background of formula for dynamic contact angle in interfoam | sebastian_vogl | OpenFOAM Running, Solving & CFD | 3 | June 22, 2009 13:25 |
Skewness angle | Jwala | Fidelity CFD | 0 | November 13, 2008 07:57 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 19:47 |
