Rayleigh-Bénard question
Old   July 17, 2006, 01:25
Default Rayleigh-Bénard question
Alej
Hello. I`m a bit confused. If you have the typical Rayleigh-Bénard problem configuration, that`s, a bidimensional cavity, with lateral walls insulated, and a constant temperature difference between vertical walls, and using Boussinesq approximation. Now, if you see how the nusselt numeber develps, on the bottom wall, and on the upper wall (by means of a numeric method), you will see that both numbers (well...the number in both locations) converge, showing the existence of a steady state. Now my question: Does it means that enters the same heat flux that leaves the cavity (because the Nu are equal)? And if the heat flux are equal, where does the energy to keep the flux moving come from? I don´t know where is the bad thing of this way of think. Maybe in the fact that`s a net heat flux, but then, why did I had two different Nusselt numbers in the unsteady stage?
Thanks for your time Alej
Rayleigh Number Thomas P. Abraham Main CFD Forum 7 November 13, 2017 03:23
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 19:43
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
