June 21, 2007, 12:07 |
Supersonic flow over flat plate
I tried to get the solution for the supersonic flow over a flat plate. After about 700 iterations, my horizontal velocity started turning negative towards the trailing edge and solution became imaginary.
Can anybody please suggest the mistake... |
June 22, 2007, 02:47 |
Re: Supersonic flow over flat plate
Years ago, I solved this same problem, reduce cell size to around 0.01 mm in the flow direction (you can have more than that in the normal direction) and the corresponding time step
June 22, 2007, 07:51 |
What if the flat plate is 0.02 mm long? Have you heard of non-dimensionalized variables? |
June 22, 2007, 08:11 |
and you, have you ever spent 3 month writing a C-programme to solve this problem? and that was 15 years ago, learn to be modest?
May 20, 2013, 02:13 |
sandy
Rep Power: 12 |
I will try for it . My cell size is 1.42*10-7 . I have the same problem. Plate length is .01mm with 70*70 grid points.
The code seems to work good results for M=4 . for M>4 it fails and gives me imaginary solutions . Does increase in Velocity has some effects on the grid ? Should i increase the grid points to 80*80 ? Any suggestion will be of great help . Thanks |
May 20, 2013, 06:03 |
#6 | |
Giles Richardson
Rep Power: 13 |
Maybe you have a sub-sonic outlet boundary, and you need to change it to supersonic boundary type ? |
May 20, 2013, 12:48 |
sandy
Rep Power: 12 |
The outlet is just an extrapolated value from the interior points . So i think thats not a problem
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
incompressible, 2-D laminar flow over flat plate... | varunjain89 | Main CFD Forum | 3 | March 6, 2012 11:13 |
Supersonic flow over a flat plate and a blunt body. | Maddy | FLUENT | 0 | August 31, 2010 16:35 |
supersonic flow past flat plate | shuo | Main CFD Forum | 0 | July 28, 2007 19:47 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
