Tip Clearance in Transonic Compressors
Old   May 2, 2000, 09:23
Default Tip Clearance in Transonic Compressors
Behnam.H.Beheshti
Hi everybody,
I am a PH.D student and I am going to start my thesis which is about studing flow field in the tip clearance of a transonic compressor. I would be so grateful if you tell me how I can start and if you introduce me some helpful references .
sincerely yours,
Behnam.H.Beheshti Sharif University of Technology
Old   May 2, 2000, 10:16
Default Re: Tip Clearance in Transonic Compressors
John C. Chien
(1). Try to read the ASME/ Journal of Turbomachinery. And ASME turbomachinery conference papers.
Old   May 2, 2000, 15:56
clifford bradford
try Budugur lakshminarayana's book on turbomachinery "fluid dynamics and heat transfer of turbomachinery" it's a good reference on anything to do with turbomachines. john also pointed you to some good reference journals. increasing papers are available online either in collections or at the authors homepage eg http://web.mit.edu/aeroastro/www/labs/GTL/ is mit's gas turbine lab homepage
Old   May 3, 2000, 03:37
Joergw Weidenfeller
Look for the book: Compressor Aerodynamics by. N. A. Cumpsty. There are also a lot of references.
Old   September 16, 2010, 16:16
Default question
N.Re.
annie is on a distinguished road
I read the Nasa report "Laser Anemometer Measurements in a Transonic Axial Flow Fan Rotor" that is about NASA rotor 67 and it has a lot of data about the 3D geometry about this blade,and I tried to produce the 3D geometry of this blade that I need it immediately but I couldn't. Does any body have the 3D geometry of this blade in IGES or STEP format?
Thanks
annie is offline   Reply With Quote
Old   September 17, 2010, 18:50
Thumbs down
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you have couple of papers on compressor , I am not getting your point?
Far is offline   Reply With Quote
Old   September 18, 2010, 01:52
N.Re.
Thanks
Old   May 20, 2013, 21:47
Liuwei
bigbigbird is on a distinguished road
Originally Posted by Joergw Weidenfeller
;8581
Do you have an e-book of Compressor Aerodynamics by .N.A.Cumpsty.If you have please send one to me.My e-mail was:jixiexueyuanliuwei@163.com
thank you very much.
bigbigbird is offline   Reply With Quote
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 13:56
Meshing in tip clearance. me Siemens 0 August 25, 2008 03:20
Tip Clearance Liam CFX 3 September 7, 2005 05:30
Tip clearance pressure distribution Karthik FLUENT 1 August 27, 2004 10:12
Tip Clearance Drona CFX 0 October 17, 2002 05:25
