May 22, 2013, 03:58 |
SIMPLE algorithm and coefficient
sina gilassi
Rep Power: 12 |
According to the book `An introduction to computational fluid dynamic the finite volume method, H K Versteeg, first edition`
page 139, the momentum equations are defined as follows: a(i,J)u(i,J) = SUM(a(nb)u(nb)) + (P(I-1,J) - P(I,J))A(i,J) + b(i,J) As SIMPLE algorithm needs P(guess) to change the above equation to scaler equation and then for each velocity u and v we have an equation. My question is about the coefficient of above equation which contains the F and D, both F and D equation contains u and v values. in page 142, the description of SIMPLE algorithm : 1) P(guess) 2) scaler equation --> iteration --> result = v(star) and u(star) 3) find P' with the continuity equation 4) correct all P,u and v 5) check the convergence 6) yes or no and loop my question is the coefficients ??!!!! their elements should be multiplied by the u(star) and v(star) ??? i am totally Someone helps me |
May 22, 2013, 04:20 |
Philipp
Rep Power: 26 |
Now, what exactly is your question? Do you want to know how the coefficients are calculated, since they need the unknown velocities?
The skeleton ran out of shampoo in the shower. |
May 22, 2013, 04:28 |
sina gilassi
Rep Power: 12 |
yes exactly, yes, yes, ... the mentioned book says:
1) guess P 2) v (star) and u(star) will be calculated ?? HOW they are calculated when the coefficient are unknown ?? |
May 22, 2013, 04:43 |
Philipp
Rep Power: 26 |
You always need to initialize all the variables. Also the velocities. Thus, you can use the initializations to calculate the coefficients. Later on you can use the "last known" velocities for that.
May 22, 2013, 05:27 |
sina gilassi
Rep Power: 12 |
Implementation of Simple Algorithm | JunaidAhmad | Main CFD Forum | 40 | November 4, 2017 13:16 |
Pressure coefficient in SIMPLE Algorithm | m.iran | Main CFD Forum | 2 | August 22, 2009 01:36 |
Question to SIMPLE algorithm by Patankar's book. | Rafal | Main CFD Forum | 2 | December 21, 2005 03:48 |
SIMPLE Algorithm | shreya | Main CFD Forum | 3 | February 22, 2004 05:54 |
2D CFD code using SIMPLE algorithm | bfan | Main CFD Forum | 3 | June 22, 2002 22:01 |
