May 29, 2013, 12:02 |
Setup Reynolds number channel flow
Rep Power: 16 |
Dear all,
I would like to know what is the general approach to impose a Reynolds number in a simulation of a channel flow with periodicity in the streamwise direction. I understand you have to consider a source term in the momentum equation which is given by friction forces, but how can I estimate this term? Besides, should I start the simulation from a stagnated field (zero velocity) or would it be better to impose a velocity close to the target velocity (the one giving the Re I want)? Any advise to help me to start this experiment is highly appreciated. Thanks in advance |
May 29, 2013, 12:30 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
the source term can be expressed both in term of a pressure gradient and a mass flow. In the first case you can think of a constant gradient equivalent to the one you have in a Poiseuille flow. The additional pressure fluctuation is solved then by the elliptic equation. |
May 29, 2013, 13:42 |
Rep Power: 16 |
Thanks for your quick reply.
So what you mean is basically to run an initial simulation to get a Poiseuille flow at the target Reynolds and then to impose that pressure gradient as source term in the next simulation, is it right? |
May 29, 2013, 13:51 |
Rep Power: 71 |
but there is an analytical solution for the pressure gradient in Poiseuille flow ...
May 30, 2013, 07:05 |
The value of the pressure gradient is different between the laminar and turbulent cases (in order to achieve the same mass flow). Check this reference:
http://www.lamc.ing.unibo.it/aimeta2.../MEM-273-0.pdf |
May 31, 2013, 14:46 |
Rep Power: 16 |
Oh excellent!
Thank you very much |
Display Modes | |
Obtaining Reynolds Number in FLUENT | Emmanuel | FLUENT | 2 | April 7, 2016 02:46 |
Low Reynolds Number Flow over a Flat Plate | Go | FLUENT | 4 | August 28, 2013 06:19 |
Flapping Airfoil Simulation in Low Reynolds Number Flow | M.Sc_Student | FLUENT | 4 | April 7, 2010 11:28 |
Reynold's number and incompressible flow | Neil | Main CFD Forum | 3 | October 24, 2006 09:11 |
Difficulties in solving a high Reynolds number Flow? | wowakai | Main CFD Forum | 10 | December 29, 1998 14:46 |
