urgent: 2d laminar boundary layer simulation
Old   July 31, 2006, 17:36
Default urgent: 2d laminar boundary layer simulation
Abhishek
I am trying to perform simulation of boundary layer of viscous laminar flow over a cylinder by writing my own code. I cannot understand how to deal with the interaction of the viscous (boundary layer) and inviscid region.
Can I just use for the whole fluid domain the simplified equation of navier-stokes equation for boundary layer in which the pressure gradient is replaced by using bernoulli's equation for free stream.
Please suggest.
Thanks Abhishek
Old   July 31, 2006, 22:21
Default Re: urgent: 2d laminar boundary layer simulation
wen long
Check out Cebeci's book.
http://www.amazon.com/gp/product/354...lance&n=283155
not cheap, but you can find it in laboratory.
Need to match: 1)velocity 2)pressure 3)zero shear at the outer edge of the boundary layer.
For strick sense of interaction, the outer flow and bl flow needs to be coupled and solved together.
From outer to bl: outer flow gives velocity and pressure gradient to drive the boundary layer flow. The bl equation is essentially 2 point bc diffusion equation in the vertial direction. Two point bc diffusion equation needs 2 boundary conditions: one at the wall which is velocity=0. The other one at the boundary layer outer edge which is velocity=U_outer. But the location of the outer edge is still unknown, so you need one more: shearstress --> 0 to find the thickness of the bl.
From bl to outer flow: once you find the thickness (location of the boundary layer outer edge), you need to go back and re-solve the outer flow for velocity and pressure, because the outer flow boundary should be placed at the interface.
Old   August 1, 2006, 19:17
Abhishek
Wen Long,
Thanks for the explanation. Can you please explain in more detail of how to calculate the boundary layer thickness.
Thanks Abhishek.
boundary layer specifications for laminar flow ranjith CFX 7 October 16, 2017 08:09
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh tomyangbath FLUENT 18 October 12, 2016 06:57
Atmospheric boundary layer simulation samygero Main CFD Forum 0 March 22, 2011 09:36
Compressible laminar boundary layer Pierre Ricco Main CFD Forum 0 July 21, 2003 13:55
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 08:47
