June 15, 2013, 13:24 |
Simple 3d-vof code based on SOLA-VOF
Anonymous
Greetings.
For own use I made a simple 3D solver for incompressible viscous fluid. The algorithm is based on the SOLA-VOF. Source code is available here: https://github.com/AntonioDe/3dvof This is the first working version, but for full use is necessary to modify the code (to add BC or output desired data) The program uses QT 4.8 and is successfully compiled both Windows and Linux. It would be great if it is useful to someone else or will be the basis for someone program 3DFOV.zip - binaries for Windows. Need Qt 4.8 for work. main.jpg - screenshot of program https://github.com/AntonioDe/3dvof/b...s/dambreak.gif - example of visualization (don't work in attach) Last edited by LiteCFD; June 15, 2013 at 13:34. Reason: error in gif |
June 16, 2013, 00:50 |
Cean
which qt libraries to install on window, mingw,vs08 or vs10? Is vs express ok to compile?
thx |
June 16, 2013, 01:09 |
#3 | |
Anonymous
In Windows I use mingw (mingw32-c++.exe (GCC) 4.7.2) + Qt 4.8.4 (MinGW version) + QtCreator (QtCreator project have extension *.pro). I try to compile in Linux, uses unknown version of Qt and gcc and it work good. Program is real simple and I think that you will not have problems with building. I don't try to compile program in any version of VS, but you can do it Please, tell me if this information is useful for you. |
SIMPLE (or SIMPLER) fortran code | Francesco Di Maio | Main CFD Forum | 6 | January 18, 2017 04:59 |
CFD code based on staggered grid | harry | Main CFD Forum | 0 | September 30, 2011 01:09 |
help!on simple method code | houkensjtu | Main CFD Forum | 0 | July 9, 2011 10:45 |
PlZ help debugging this simple code | Jinfeng | Fluent UDF and Scheme Programming | 1 | October 6, 2009 18:15 |
free VOF source code? | Pei-Ying Hsieh | Main CFD Forum | 5 | July 5, 2000 13:54 |
