June 20, 2013, 16:37 |
Yplus
rayan
Rep Power: 12 |
I want to know what's the "Y+" and what's the effect of YPLUS, WHY i MUST CHOISE az define value for Yplus, in LES model why i must choise Yplus =1? Thanks for your explications |
June 21, 2013, 05:22 |
reply of Y+
CHAO
Rep Power: 13 |
Hi.
Y+ represents the suitability evaluation of boundary layer thickness. |
June 21, 2013, 07:50 |
Y+ is importsant in relation to the known features of turbulent velocity profiles near the wall. For Equilibrium boundary layers, at low y+ (<5) it is linear, for high values (>30-50) and up to 0.1 delta (thickness of the boundary layer) it is logarithmic. For the first point near the wall in your grid you can define a value for y+, then you know if it is too high to resolve the full velocity profile or not. If not, you need a low Re turbulence model (which can go down to the wall), otherwise you will need a standard model with wall functions.
This is the basic matter in RANS. For LES it is quite different and y+ alone is useless. Wall parallel grid spacings matters as well. But this is a much longer story... |
June 21, 2013, 08:05 |
another question
CHAO
Rep Power: 13 |
That is a wonderful explanation.
Well,may I know if you know about the Detailed chemical reaction mechanism of gasoline and suitable references on this matter? Any help would be greatly appreciated. |
June 21, 2013, 09:48 |
#6 | |
rayan
Rep Power: 12 |
Verry good explanation
Thanks a lot I begin to undestund the importance of Y+ Thanks Quote:
Display Modes | |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
How can Modify yPlus function to be yPlus not yStar? | immortality | OpenFOAM Running, Solving & CFD | 0 | May 5, 2013 14:16 |
which yplus (SST) | sanchezz | CFX | 17 | January 11, 2010 05:45 |
X-Y plot of Yplus in Fluent 5.3 | Luo | FLUENT | 24 | April 11, 2000 07:07 |
heat transfer coefficients with "bad" yplus | Andrew | Main CFD Forum | 4 | April 8, 1999 05:43 |
